I have a front loader and now a snow blade in the rear. I set the draft control leaver in horizontal position, and the rear blade lift only half way up.
If I set it in vertical position it don't move at all, but if i puch the leaver against the rear of the tractor it the blade startet to lift.
Going from front loader to scraper blade and scraper blade to front loader I have to pull the aux buttun when the lift or blade are on it's way up, to get the other to lift.
If I lift the loader or blade all the way up and then pull or push the aux button, then there are no movment from the blader or loader. And when this happens there are no sound from the hyd pump.
Sometimes it works like there never was any problems, but most of the time it it will act up. Didn't have this problem when dry testing the system before the snow came,
but now after only a short snow remove job. I think the problem has been there all the time, but it got more noticable when it had to perform
What could be my problem? I have a feeling it is the top plate with the aux funtion, but this don't explain the no sound from the pump.
It has new and plenty of oil
I also noticed that the main controll spring plunger would not move when I pushed the rocker...
