First Tractor Petrol Dexta
Posted: Thu Mar 15, 2012 1:09 pm
HI,
I just recently purchased a Petrol Dexta, at the time of Purchase all I was chasing was somthing to run a slahser that had a two stage clutch that was cheap (needs work). I ended up with the petrol Dexta as it was cheap and working, the seller did not know what he had other than it was a Ford and Petrol I had to work the rest out myself.
The seller also advised that there were many problems, tyres are shot motor was over heated water pump leaks lacks power needs work, when I arrived to collect it started and drove up onto the trailer so I was happy that it was worth working on. It also came with the slasher in very poor order.
when I got it home I did some simple things to see if I can get it to slash the grass now as it is about 7ft tall and a little out of hand, thankfully all I had to do was manufacture a slasher blade assembly buy new blades water pump and ignition leads replace the fuel line and remove a blockage at the fuel tap (someone tried to dodgy it up with the rubber ring as the pipe and olive was leaking) also had to clean the air intake it was bad very bad, it works fine now and is doing the job although this tractor needs alot of love.
First off I want to get everything working as it should again before striping this down cleaning and painting, below is a list of what I think needs to be done to have it back to working:
new generator existing was destroyed inside and the spare that came with it is shorted between shaft and armeture
new batt the one on it holds charge just enough to start it once
new tires
new exhuast
new air cleaner pre cleaner
new grill and lights
new wire for missing lights etc
tacho and cable
correct lights for the dash
new dash surround
new throtle stick (it split and is welded on now)
missing the auto control lever for the hydrolics
new leveling box
hand brake replacement kit or a new one
new gear sticks (you can easily have it in reverse and 1st at the same time)
all new filters and oils Transmission must have some water in it too as it is milky although if it was not for the color you might think it was fine?
secound fuel tank is not connected?
I am sure there is more that I cannot think of right now
some items I can get new aftermarket at the local tractor shop (I am in Brisbane) but some of this stuff I cannot get from them, any one know if there is a wrecker that can help?
so far I have been geting the job done by figuring it out as I go as I did not find this site until recently, any help or ideas would be nice especialy in regards to the things I should be working on or checking ASAP as I am using this tractor and if I can prevent a major problem but checking something now than that might save me alot of money.
any way let me know what you think and what I should do right away.
I have lots of photos here:
http://s582.photobucket.com/upload/albums/daniel_veld/
http://i582.photobucket.com/albums/ss26 ... 183513.jpg
http://i582.photobucket.com/albums/ss26 ... 183527.jpg
http://i582.photobucket.com/albums/ss26 ... 183628.jpg
http://i582.photobucket.com/albums/ss26 ... 183708.jpg
http://i582.photobucket.com/albums/ss26 ... 183713.jpg
http://i582.photobucket.com/albums/ss26 ... 183752.jpg
http://i582.photobucket.com/albums/ss26 ... 063109.jpg
http://i582.photobucket.com/albums/ss26 ... 063120.jpg
http://i582.photobucket.com/albums/ss26 ... 063128.jpg
http://i582.photobucket.com/albums/ss26 ... 063137.jpg
http://i582.photobucket.com/albums/ss26 ... 063143.jpg
http://i582.photobucket.com/albums/ss26 ... 063154.jpg
http://i582.photobucket.com/albums/ss26 ... 063203.jpg
http://i582.photobucket.com/albums/ss26 ... 063224.jpg
http://i582.photobucket.com/albums/ss26 ... 063231.jpg
http://i582.photobucket.com/albums/ss26 ... 063237.jpg
http://i582.photobucket.com/albums/ss26 ... 063245.jpg
(not sure if the above is the correct link?)
I was going to start with the following:
lever for the auto hight adjustment on the hydrulics as this might make slashing easy as the slasher has no rear wheel and the ground is up and down
checking fluids each day.
once the slashing is done I was going to cover it for a few months while I gather all the parts to rebuild the motor and fix/replace all the above strip clean rebuild and paint, that is why I was thinking of just leaving the fluids and filters until than, reason for the engine rebuild is that I see alittle coolant at the back of the motor and it should not be there also compresion is only at 80 to 90PSI in each chamber and it is geting hot quickly (this also is not helped by slashing in first as the grass is long and thick and the radiator needs to be cleaned alot due to grass seeds). I was also wondering how hard it is to strip this thing down all the way as all the seals are weeping not fully dripping all over the place but enough of a leake for me to do somthing about. how hard is it to get all the correct gaskets? so far it seems that the engine rebuild should be simple as I can use the kit from a fergusin 135? in the event that I cannot afford everything before I have to slash again what would be the best items to focus on first? although I dont fully trust the motor it is still working fine so I am unsure how high a priority this should be?
I have read all the manuals and data I can find on this and still it took me a while to figure out how everything works and still learning as this is a first tractor for me so I appreciate all the help.
new tires
new exhuast
tacho and cable
new dash surround
new leveling box
