dexta struggling to start
DEXTAS
Post by DEXTAS »
hi, i am woundering if anyonw would know why my dexta isnt starting properly.the engine is fully recontioned except the fuel pump.it takes about a minute to start :? but once i start it and stop it it starts first turn :?: any help will be usefull
thanks kyle :D
Re: dexta struggling to start
Post by Bensdexta »
Are you using the heater and primer?
If so are they working?
tom lad
Post by tom lad »
hi
air in fuel system , wont start till its primed its self ???? just a thought
tom
DEXTAS
Post by DEXTAS »
i am using the primer but im not using the heater as i dont have it on yet. the desiel pump wouldnt be an issue?
conar22
Post by conar22 »
have you tried to bleed the fuel system by slackening the bleed screw on top of the fuel filter,then at the injector pump,then finally slacken the injector pipes up at the injector?
Gavin
Post by Gavin »
I would think the lack of heater is the problem. Priming with fuel is not the way to start - it needs heat
Fordson Super Dexta, Ford 4610, and Ford 3000
DEXTAS
Post by DEXTAS »
yes i bled everything.i will get the heater on it and try it then :D
thanks for the help :clap:
jc24fan
Post by jc24fan »
Speaking of heaters, we have what we guess to be a 61 Dexta diesel. Wher is the heater supposed to go? It does not have glow plugs.
Post by Bensdexta »
jc24fan wrote:Speaking of heaters, we have what we guess to be a 61 Dexta diesel. Wher is the heater supposed to go? It does not have glow plugs.
On the air inlet manifold, RH side of the engine. :wink:
tom lad
Post by tom lad »
hi
the thread dexta newbe ....
shows a nice photo of the heater
