Dexta front axle
Posted: Sun Apr 15, 2012 7:55 pm
After a lot of knuckle scraping i managed to get the bashed nose cone off my Dexta without damaging any original parts/brackets. This has then let me take off the radiator (which leaks
) and strip off a few more bits at the front end.
Can anyone tell me how the front axle comes off? it pivots on a tube which the starting handle passes through. There is a keeper plate with a single bolt through which i have taken off that looks like it should then let me knock the central tube out, but it won't budge. I've soaked it in release fluid but don't want to spend too long bashing away at something that might not want bashing
There is a spacer ring, the axle, then a further spacer at the back if i remember correctly.
Also drained off the oil. It was like black treacle--don't think it been changed for a long time.
