I have just about finished restoring my 58' Dexta however, I am noticing that there is water coming from the bolts that hold the exhaust manifold on and also from behind the combustion chamber caps
I'm thinking here that this must be head gasket related, I have totally rebuilt this engine, new pistons, liners, shell bearings etc with a new Agriline cylinder head.
The head is torqued to the correct torque, although I did not use a gasket sealing paste, do you guys think this is the problem?
The tractor has only been run for approx 1 hour.
Your thoughts appreciated!
