I have a question. My oil pan gasket is old and leaking can I replace the oil pan gasket with out removing the engine from the bell housing??? all I want to do is install a new oil pan gasket....the easy way.. with a new gasket...
Cheers.... bill
(Moved to the Dexta Board)
Dexta sump oil leak
Dexta sump oil leak
Mike Kuscher
Re: Dexta sump oil leak
Front end has to come off from memory. Make sure you replace the front and rear half moon cork seals whilst you have it off. Otherwise you'll be splitting the tractor thinking the rear main seal has gone when it hasn't...like I did...twice.
Make it Better for the next person and We all end up Better off.
