how are fordson dexta grease nipples fitted ??
the head seems round , no obvious hexagon head , ... press fit ??
i've one missing of the diff lock pedal
are they still avalable , or just drill and tap it for a modern one ?
grease nipples
grease nipples
Re: grease nipples
If they are the same as the Major ones they are press fit if they have no hex on. I can still get them here in Canada off the shelf we can get most odd stuff like that here easily
but in the U.K or other places I don't know
. if you wanted to it would not be a problem to maybe drill a hole out larger if needed and tap to a thread if you can get the part off to do it
Re: grease nipples
thanx m8
never noticed the reply sorry
yes no hex on mine .
