dexta clutch
dexta clutch
hi all, my name is adam and recently my friend leigh and myself bought a 1960 fordson dexta, we have playing around with it trying to get it ready for show at the end of august but there is one thing holding us up, the tractor came with a mostly new clutch but the part that the clutch all fits together on (basket?) has been welded in the past and is also broken on another place. we have been trying to find a replacement for this but as we still new to it we don't know were to look. if anyone on here would know were we could go, or have the part we are after up for sale any information would be greatly appreciated. again i must apologize if i have the terminology wrong as i said before we are still new.
Thanks in advance
Adam
Thanks in advance
Adam
Re: dexta clutch
hi welcome to the board of fordson , there is two different type clucthes
know as live and standered type , if you could post a picture it would give an idea
of which type you have, the standered are alot cheaper than live
if you have to buy acompleat unit, there are alot of places selling them but as isay you will
need to know which type you have
regards sky blue
Re: dexta clutch
Live clutch.
Standard Clutch
Pictures from the CNH parts site.
Standard Clutch
Re: dexta clutch
[Brian: the hotlinks don't work - you forbade them!!
I suggest you check out which parts you need on the dexta parts list: http://www.fordsontractorpages.nl/phpbb ... f=7&t=4233
Re: dexta clutch
Links work fine for me Ben, they come up in a little window at the bottom of the screen, just click on that and there is your picture.
Re: dexta clutch
link doesn't work for me either FORBIDDEN
Re: dexta clutch
No joy here - just get a banner saying "hotlinking from this site is forbidden".Brian wrote:Links work fine for me Ben, they come up in a little window at the bottom of the screen, just click on that and there is your picture.
Perhaps because the link is to https:
Re: dexta clutch
hi guys, thanks for replies, i cant get the links to work ether, i cant get a pic of it yet but i know its a 9" and a 12 spring?? not sure if that makes any sense to anyone?
the hunt goes on!!
the hunt goes on!!
Re: dexta clutch
images of clutchs work now
Re: dexta clutch
Brilliant, it's a live clutch that I need the part for,
Re: dexta clutch
the bit im after is on bottom left with the red ring around it, as you can see it is broken at 12 oclock position.
thanks again, adam
Re: dexta clutch
if have already tried local breakers yard with no luck ,, if you goggle [agriline products ]
uk they should be able to fix you up or dunlop tractor spares there are ahost of suppliers out there
also ebay they come up from time to time
good luck sky blue
Re: dexta clutch
Hi, read the post "Rod and Main Bearing Surfaces", starts at June 17, 2010. Still have the rest of my junk....
Re: dexta clutch
hi eric, i have sent you a pm but it says they are stuck in my outbox???? let me know if you get them,
Ads
Ads
Re: dexta clutch
Got them. Will take apart the clutch for check . Is a little busy now, but will try in the weekend.
Re: dexta clutch
Wow that would be grate thank you very much for going through the bother,
Ads
Ads
Re: dexta clutch
Well, seems to be ok.
Send me a pm and we make a deal....
Re: dexta clutch
Hi guys, I'm still after the clutch part stated above , lost contact with erik b so anyone els got anything?? Cheers all!!
Tubal Cain
- Site Expert Team
Re: dexta clutch
I have aused one which you are welcome to.
Gerald
Gerald
Re: dexta clutch
That would be brilliant
how should we go about it? An Were abouts are you based?
Adam
Adam
Tubal Cain
- Site Expert Team
Re: dexta clutch
I live in Pembrokeshire, provided that you live in the UK the cost of delivering the plate to you would be about £10.00, I need your post code in order to obtain a true cost.
If you have a Paypal account you can transfer the money to my account.
Gerald
Gerald
