Power take off leaver
Posted: Tue Jun 19, 2012 6:31 pm
by Trevorthetractor
Can any of you knowledgeable guys out there tell me how to remove the power take off engagement leaver? It seems to be on a taper pin with a nut & washer. It wont budge and i don’t want to damage the thread. It needs to come off to replace the clutch pedal bush. Many thanks
Re: Power take off leaver
Posted: Tue Jun 19, 2012 9:09 pm
by stugreen
Once you have taken the nut off I'd just a punch and tap the pin out from the front side so it goes out the rear side, try a little bit of heat maybe, as a second thort coil you tighten the nut up and try with some grips to turn the pin and try and find a "easy spot"
Stu
Posted: Wed Jun 20, 2012 6:11 pm
by Jerry Coles
The cotter pin has a taper and a shoulder that lines up with both the Lever and the shaft.
Loosen the nut a turn or two and give it a tap and the pin should go backwards.
Before you loosen it I suggest you mark the lever and shaft as well as the end of the cotter pin so that you can line them up when refitting .
Posted: Wed Jun 20, 2012 9:14 pm
by Trevorthetractor
Thank you, i will try that tomorrow
Posted: Thu Jun 21, 2012 11:11 pm
by Trevorthetractor
Great job done, footplate off and some heat and a sharp tap with a lump hammer knocked out the taper pin. thanks for the info.
