Tom,
Have you checked the resistance of your heater switch when open & closed? You'll need to remove it from the dash first. Of course, when open (button released) it should be infinity Ohms (ie open circuit); when closed (button pressed) it should be zero. So long as your switch passes these simple tests it
should be OK.
A couple of yrs ago there was a prob with the usual suppliers with shoddy switches in which one of the terminals on the back was shorted with the back plate, so I sent mine back and waited over 6months till they got a new batch of servicable ones. There's a post about it here somewhere.
Ref ignition switches: Yes the switches on early Dextas with integral light/ignition key were/are a constant source of trouble since the rain runs in and corrodes the switch. That's what happened on our Dex over 30 yrs ago.
Later Dexs/Supers, from ~1962 have separate light switch with the key switch moved to the RH side of the lower dash. So thats what I've done; got a 2nd hand original Super D light-only switch for the hole lower left of dash. But I got a Hobbs/Honeywell key switch, which fits great in the Super D position. This is a much better engineered switch c/w rubber cover. A bonus is that it has a coded key unlike the standard tractor keys which are all the same - how secure is that!!
There's a thread about the switch here:
http://www.fordsontractorpages.nl/phpbb ... 22&p=10197
Edit: I got my heater switch from Southern Counties. However, I believe there is only one manufacturer, so prob doesn't make much difference where you get it - just test it before you install it. Remember that for most of these repro parts, we are the Quality Control Dept!
