with the fuel tap/ jet thingy off the tractor but plumbed in to test , should i see a mist of fuel when i work the primer button ?
the tap is turned on but the levers missin on mine so bad to tell if on or off when fitted
can the atomizer / jet be stripped down ?
think i just need a new one
tested with air line , only faint flow , wrong way with high pressure
just weeps from the tap barrel when fitted , the jet hole is dry .
