rear brake shaft springs
dave100
Post by dave100 »
Hi all im in the process of restoring my 58 dexta just replaced rear axle oil seals and washed out rear axle housing, having had to grind a line of weld between top lift cover and back end, why someone had welded the cover on is a mystery to us all but never mind anyway back to my question, does anyone know where i can get the springs that are on the brake shafts on either side that holds a washer to back plate persumably as a dust cover, i have tried all the usual companies without any luck as anyone else succesfully sourced these parts thanks
Re: rear brake shaft springs
Post by Bensdexta »
This any help: http://www.fordsontractorpages.nl/phpbb ... rake#p9753
Seems Massey can supply them. :wink:
