Swinging draw bar
Noblett
Swinging draw bar
Post by Noblett »
I have managed to piece together the main parts of a swinging draw bar assembly however there are a few pins that I need to be able to use it. I am after the pivot pin that holds the draw bar in place part no 957e-4727, the adjusting pins and clips part no 957e-4737 and 113814-es and support bracket pin part no E623-t-9. If any one knows where I could get these I would be very grateful. Many thanks. John
Re: Swinging draw bar
Post by Bensdexta »
If all else fails, those pins can be made fairly easily by a machine shop. :wink:
Noblett
Post by Noblett »
I can find plenty of pins that I could make fit but not with the correct clips etc i don't know if anyone else had managed to find the correct ones. John
Post by Bensdexta »
Yes the original clips are hard to come by as they corrode.
I think any R-clip will serve the purpose, if you're not hyper about originality. :wink:
