VonZu's '62 Super Dexta
Posted: Thu Dec 20, 2012 11:59 pm
by VonZU
Re: VonZu's '62 Super Dexta
Posted: Fri Dec 21, 2012 12:05 am
by VonZU
A while ago, the head gasket blew between two of the cylinders. It's quite a while ago, and I cant remember which ones.
The head was sent off to refurbishment at a local engine shop.
Now, this is quite some time ago, and much has been forgotten.
Recently I startet assembling again, and came to a halt because I couldn't remember if there were washers under the head retaining nuts.
When I zoom in on this picture, it seems like there are washers.
But today, I have none. The head is put back, but I haven't torqued it up.
Can anyone confirm that I lack these washers, and maybe provide some dimensions and materials to allow me to purchase new ones?
I have the workshop manual for the tractor, but it isn't much help in this respect.
Posted: Fri Dec 21, 2012 12:06 am
by Bensdexta
What front loader have you?
What will she lift front and rear?
Many thanks for the nice pics
Posted: Fri Dec 21, 2012 12:11 am
by VonZU
Posted: Fri Dec 21, 2012 12:18 am
by VonZU
Bensdexta wrote:What front loader have you?
It's made by a local Norwegian company called "Malm Orstad". They made a lot of front loaders for Fordsons and Fords. Mainly two versions, the "agricultural" and the "industrial". This one is an agricultural.
Bensdexta wrote:What will she lift front and rear?
I don't know exactly. In the rear I get approx 1000kg all the way up. Any more than that, and I will have to use persuasive means to get it up
I can keep 1300kg up, if I "persuade" it up first.
In the front it's above 1000kg, but not by much. Max 1200kg I assume.
Bensdexta wrote:Many thanks for the nice pics
You're welcome
Posted: Fri Dec 21, 2012 12:22 am
by frode
Great! Where in Norway are you?
Post some pics of the 754!!
Posted: Fri Dec 21, 2012 12:25 am
by VonZU
I'm from Jæren. 50km south of Stavanger.
The 754 is in a sorry state at the moment. It's been used hard for a lifetime, but is not beyond repair.
I'll make a project thread on it as soon as we start working on it again.
Posted: Fri Dec 21, 2012 12:33 am
by frode
VonZU wrote:I'm from Jæren. 50km south of Stavanger.
Ok! Post some pictures anyway
Has it been used in the forest?
Posted: Fri Dec 21, 2012 1:24 am
by VonZU
Posted: Fri Dec 21, 2012 10:19 am
by Bensdexta
VonZU wrote:In the rear I get approx 1000kg all the way up. Any more than that, and I will have to use persuasive means to get it up
I can keep 1300kg up, if I "persuade" it up first. In the front it's above 1000kg, but not by much. Max 1200kg I assume.
That's a big lift, hydraulics must be in good condition.
Posted: Fri Dec 21, 2012 10:23 am
by Bensdexta
VonZU wrote:Recently I startet assembling again, and came to a halt because I couldn't remember if there were washers under the head retaining nuts.
The parts list mentions a washer for one of the head studs, but not the others. Also no mention of washers in the workshop manual.
I'm sure one of the experts will be along to answer soon.
Happy Christmas.
Posted: Fri Dec 21, 2012 10:49 am
by VonZU
I think I know which one bolt you refer to. It's the one all the way to the rear.
Yes, I hope some experts can clarify this for me. I don't want to put it back together with more errors than it had
Posted: Fri Dec 21, 2012 11:00 am
by VonZU
Bensdexta wrote:VonZU wrote:In the rear I get approx 1000kg all the way up. Any more than that, and I will have to use persuasive means to get it up
Yes, it's not bad at all. But it has been maintained fairly well by my father through the years. Presicion on the hydraulics is another thing. That could absolutely have been better. But I'm not doing anything with that for now. It works well enough for my use as it is. Other things don't.
Posted: Fri Dec 21, 2012 11:04 am
by VonZU
I found some old pictures of it, from when it was a proper workhorse in more or less daily use.
We never used the front loader on it much, as we had the 754 with a substantially stronger and better front loader.
