would anyone have any idea when the sump changed on the s/dexta and dexta
if any one has a dexta possible n/p or s/dexta n/p could they check and see
if the sump has the sump plate on the bottom which holds the strainer, i
am trying to find out the date which they changed and done away with the
bolt on strainer, sky blue
new type sump
Re: new type sump
thanks ben for reply, i think if iam right that all engines in the n/p range had them
without the bolt on strainer.
