Posts: 2666 Joined: Mon Sep 15, 2008 12:59 pm
Post
by Bensdexta » Mon Jan 07, 2013 12:18 am
Below is a pic of the front and rear bonnet retaining catches.
Can someone confirm that the front catch bolts onto the
inside of the nose cone and the rear catch bolts onto the
outside of the stub on the bulkhead.
Just trying to get the bonnet to fit....fun ehh.... !
TIA
JC
Posts: 1092 Joined: Thu Apr 17, 2008 3:48 am
Post
by JC » Mon Jan 07, 2013 1:48 am
That's the way they are on my Dexta, Ben. The Majors and County, too!
Post
by Bensdexta » Mon Jan 07, 2013 10:36 am
Many thanks!
Brian Cox
Posts: 297 Joined: Sun Aug 07, 2011 7:58 pm
Post
by Brian Cox » Mon Jan 07, 2013 8:01 pm
Fun! you could wrestle for long and weary and it still won't seem right. I did anyway. Best of luck
Post
by Bensdexta » Wed Jan 09, 2013 1:22 am
Brian Cox wrote: Fun! you could wrestle for long and weary and it still won't seem right. I did anyway. Best of luck
Fortunately not looking too bad a fit, now we got the catches the right way around.
Apart from the usual problem of the LH rear edge tending to stick out too far by the battery compartment. Will try a little more bending....
Dextapaul
Posts: 16 Joined: Thu Jun 03, 2021 7:36 pm
Post
by Dextapaul » Sun Feb 20, 2022 7:49 pm
Are both catches the same? They look the same to me but I am struggling to get the RH catch to well, catch.
I see there are part numbers for LH and RH which makes me thing they are different.
Any help much appreciated! I've been wrestling with the bonnet for hours today!
Posts: 2556 Joined: Fri Jun 26, 2020 12:01 am
Post
by Billy26F5 » Sun Feb 20, 2022 8:22 pm
I'll post pics of Davie later, you should see what you need. The two catches are different.
Dextapaul
Post
by Dextapaul » Sun Feb 20, 2022 9:27 pm
Ah, ok thanks Sandy
Post
by Billy26F5 » Mon Feb 21, 2022 10:33 pm
Sorry for the delay, here's the pic.
The front catch is like the Major front catch (E1ADKN-16757), but the rear one is a different part unique to the Dexta (957E-16773B).
Dextapaul
Post
by Dextapaul » Sun Feb 27, 2022 9:06 pm
Thanks Sandy, much appreciated
Are the latches which are on the back of the bonnet the same each side or different?
Post
by Billy26F5 » Mon Feb 28, 2022 3:07 pm
The front and back latches are the same, part number E1ADKN-16659, only on the LH side.
Posts: 190 Joined: Sun Oct 14, 2018 11:14 am
Post
by Old Hywel » Mon Feb 28, 2022 7:44 pm
Strange, others can obviously see the photo in the initial post, but all I get is a small box around the word ‘image’.
No amount of clicking/tapping has any effect.
Post
by Billy26F5 » Mon Feb 28, 2022 9:48 pm
Old Hywel wrote: ↑ Mon Feb 28, 2022 7:44 pm
I have the same problem too, but that's quite an old post.
Post
by Old Hywel » Mon Feb 28, 2022 10:26 pm
So it is, recently resurrected.
