hydrulics
sky blue
hydrulics
Post by sky blue »
This has probley been cover before but cant seem to find it , the hydrulics
seem to have a mind of their own when in position control, they will lift
ok all the way up, put if i lift a implement say about 1/4 way up it will
lift ok and stop as it should but then when travelling a short distance they will
lift all the way up to the top on their own, this is without the lever been moved , anyone any idea
what could be causing this :scratchhead: , thanks in advance sky blue
sky blue
Re: hydrulics
Post by sky blue »
just found the post on the hydrulics problem on the search :oops:
[ operator error] should always be in draft when using external hyds
got it sorted another one marked up to Brain, :beer:
sky blue
