The duel clutch in my dexta is stating to slip on the transmission plate. can these clutch units be effectivly repaired or have I got to shell out for a whole new clutch assembly?
Regards,
clutch replacement
Re: clutch replacement
you only need a new plate but if it's a dual clutch you will maybe have to find someone to do the job. I got an expert from my local vintage tractor club to fit mine
