Engine Breathing pipe leaking diesel????
Started my dexta for the 1st time in 4months after being sat there and its pissing diesal out of the engine breaking pipe
									Owner of a 1961 fordson dexta restyled model
				gjsteed
Re: Dexta leaking fuel from injector
Is the nut that holds the pipe in place tight ? (But not to tight,you may run the threads!) Maybe you have put it on the wrong threads and now the copper pipe isn't seated right ..double check everything for piece of mind !
sorry its the engine breathing pipegjsteed wrote:Is the nut that holds the pipe in place tight ? (But not to tight,you may run the threads!) Maybe you have put it on the wrong threads and now the copper pipe isn't seated right ..double check everything for piece of mind !
						Re: Engine Breathing pipe leaking diesel????
which pipe is it, it the breather coming from
top of egine and running down right hand side behind stater or is it the pipe with
pig tail from injection pump that diesel is coming from,
pig tail from injection pump diesel is just running out of itsky blue wrote:which pipe is it, it the breather coming from
				Tubal Cain
 - Site Expert Team
The odd drip from this pipe is acceptable.
If as you suggest it is running in a constant stream, your injection pump is in need of overhaul.
Gerald
Gerald
It only dripped when i 1st got it but its been say for 4months doing nothing went for a start and it was pouring out do i need to get it sent away or is it an easy job to get it fixed?
				Tubal Cain
 - Site Expert Team
As the tractor has been standing idle for several months, I would give it a good run to see if that will cure it.
If it is still leaking then it probably requires to be overhauled, in which case you need to remove the injection pump and take it to a firm who specialise in overhauling Diesel injection equipment. The last pump that I had reconditioned cost £270.00 with the VAT!
Gerald
Gerald
				Tubal Cain
 - Site Expert Team
Further to my previous post I have just had a look at the drawing for the injection pump, the leakage that you are experiencing could be due to the lift pump diaphragm being punctured.  In hind sight this is a more likely cause of a continous  fuel flow from the pig tail pipe, so you need to strip the lift pump down and examine it.  Lift pump repair kits and complete new lift pumps are available.
Gerald
						Gerald
