Hello;
Who can tell me which thermostat has to be used for the normal Dexta?
Sparex.com has two mensioned, one of 74° en one of 88°C
I discovered my temperaturegauge funktioned correctly in boling hot water,
but when the engine is at tempetarure temperaturegauge did not react so I think it is an broken thermostat.
Auke
Thermostat temperture
Re: Thermostat temperture
It should be 77 to 81 so this will keep you right, its the lower temp. thermostat
Thanks Brian
