removing injector pump
Posted: Fri Apr 19, 2013 5:16 pm
by rich2a
Hi, I need to remove the injector pump on the dexta to get at/inspect a large crack between the core plugs
. Any tips on the job, including re fitting and timing etc?. I did search for the w/shop manual but its gone! thanks in advance, rich.
Re: removing injector pump
Posted: Sat Apr 20, 2013 8:02 pm
by rich2a
No comments at all then????
Posted: Sat Apr 20, 2013 8:38 pm
by Brian Cox
Hi Rich, you will get info on Stefans workshop manual link , it is in the first item
Posted: Sat Apr 20, 2013 8:56 pm
by Dextapower
Is there much water coming out of the crack or is it just a drop? I suppose if it just a small crack you could drill a small hole at each end of crack. Then open crack abit and fill it with jb weld. To remove injecter pump you would open the timing inspection cover and mark the timing gear and timing cover with ink so that it aline. Then undue 5 nuts that holding pump and it should slide out. When putting pump back just aline ink that you marked is aline and job done!
Posted: Sun Apr 21, 2013 10:22 am
by sky blue
hi i replyed but the computer went just as i submited, , it can be a bit fustrating
when you are waiting for a reply as i well know but usally someone will get back to you.
there are 5 bolts, the back and the bottom are really awkward, make sure
you have a gasket or at least gasket paper of the right thickness when replacing the
pump just incase old one gets damaged
good luck sky blue
Posted: Sun Apr 21, 2013 7:41 pm
by rich2a
Thanks for all replies!! Aye the crack extends between both core plugs
I am hoping to tackle it again during the week. Pump removal was OK, even found all the nuts!! Cheers , Rich.
