Hi all
trying to replace temperature gauge on a Dexta.
It seems I just cannot drop the capillary bulb and bush down through the hole in the tank!
Do I have to remove the tank mounting bolts to allow space for the bulb and bush to drop down beside the steering column?
Cheers to all
									Temperature gauge capilliary wire route
Re: Temperature gauge capilliary wire route
Unfortunately yes
 If I remember correctly, I had to pull my steering wheel and remove tank to feed the end thru the hole.
i was always able with a my dextas to feed the cable down the hole carefully
at the bottom was a bit tricky as the nut sticks but with a bit of wriggling it does go through, i
diddnt need to lift tank up but it may make it easyer,
good luck sky blue
good luck sky blue
