Wiring problem
Posted: Sat Apr 27, 2013 5:21 pm
by Vulgunx
So i have wired up my dexta and my dyanmo and oil pressure light stays on? So i got a new switch and got my dynamo recond and the lights are still staying on? and my batterey still isnt getting charged from my dynamo? HELP!!! i have a tractor show 4weeks so need this done asap :)
Re: Wiring problem
Posted: Mon Apr 29, 2013 4:22 pm
by Vulgunx
Anyone?
Re: Wiring problem
Posted: Mon Apr 29, 2013 6:13 pm
by Bensdexta
Have you checked the voltage across the battery terminals when you rev the engine - it should be around 14V?
How old is your control box? It may be u/s.
Have a read of this:
http://www.dbtc.co.uk/index.php?name=PN ... 09&start=0
Re: Wiring problem
Posted: Mon Apr 29, 2013 8:24 pm
by scoobyjim
Have you put a complete new harness in. If you have a 12v supply to the dynamo through the small wire you should have over 14v coming out of the big wire. If you do its your control box
Re: Wiring problem
Posted: Mon Apr 29, 2013 8:25 pm
by Vulgunx
It has a recond and everything electric is brand new :(
Re: Wiring problem
Posted: Tue Apr 30, 2013 4:22 am
by scoobyjim
So do you have 12 in and more coming out.
Re: Wiring problem
Posted: Tue Apr 30, 2013 8:45 am
by russelm
Did you flash the Dynamo?
The system works by some residual magnetism in the dynamo producing a voltage as it starts to rotate, once it gets upto speed, this volatge pulls in a contact in the regulator and the field is energised.
If you dont flash the dynamo then there will be no volts to pull the contact in.
Re: Wiring problem
Posted: Tue Apr 30, 2013 11:17 am
by Vulgunx
i put this bit aside at the moment since im in the shit im changing my track rod ends since they are pooped and cant get them off i have got them glowing orange and still cant get it off? any ideas
Re: Wiring problem
Posted: Tue Apr 30, 2013 11:34 am
by Bensdexta
Vulgunx wrote:i put this bit aside at the moment since im in the shit im changing my track rod ends since they are pooped and cant get them off i have got them glowing orange and still cant get it off? any ideas
Hit it on the side with something solid on the other side.
And start a new subject thread on this problem!
Re: Wiring problem
Posted: Tue Apr 30, 2013 5:39 pm
by scoobyjim
Ball joint splitter. Put some weight on and give it a knock with a hammer. It will come straight off.
Re: Wiring problem
Posted: Tue Apr 30, 2013 8:47 pm
by Vulgunx
That problem fixed going to borrow my mates amp tester so will keep you guys posted also what will the problem be with my oil pressure light staying on?
Re: Wiring problem
Posted: Wed May 01, 2013 11:52 pm
by scoobyjim
Unless you have wired it wrong the sender unit is faulty in the block. Check the resistance when the engine is stopped and when you start it the resistance should change.
Or you have low oil pressure lol
Re: Wiring problem
Posted: Thu May 02, 2013 11:00 am
by Jerry Coles
The Oil pressure switch works by open circuiting the connector when the pressure is reached, this removes the return from the Oil lamp to ground. If you oil lamp is on all the time try disconnecting the wire from the oil switch - the lamp should go out. If it doesn't go out then that wire is grounded somewhere from the lampholder down. Possibly crushed or damaged. If the lamp does go out then the oil pressure switch is suspect or you have no/insufficient oil pressure!
You can get an adapter to take an oil pressure gauge which will give you a more accurate idea of your oil pressure.
If you want to borrow one I have one so PM me and I'll send it off to you. I rebuilt a Dexta engine and it was with great relief that I saw the needle on the gauge go up as it fired up for the first time. :D
Bath
UK
Re: Wiring problem
Posted: Thu May 02, 2013 12:23 pm
by Bensdexta
Jerry Coles wrote:You can get an adapter to take an oil pressure gauge which will give you a more accurate idea of your oil pressure.
Hi Jerry,
Have you a pic or a description of your adapter and oil pressure gauge?
Where did you get it?
Cheers! :wink:
Re: Wiring problem
Posted: Thu May 02, 2013 2:20 pm
by Jerry Coles
Oil pressure guage
You may have to get another adaptor to take the later thread size (try a plumbers merchants or hydraulic agent)
http://s1106.photobucket.com/user/oldtr ... ort=3&o=24.
Re: Wiring problem
Posted: Thu May 02, 2013 3:23 pm
by Vulgunx
Went to test that idea took the wire of the oil pressure switch the light went out put it back on light came on started the tractor the light goes off???? stopped the tractor light goes off started light goes off like it should took the wire off stopped the tractor put wire back on and the light just stays on? and i checked the wire cannot be crushed since i can move it around the steering box shaft?? and my oil pressure cant be low since i drove my tractor 5miles the other day to bring it home from the unit
Re: Wiring problem
Posted: Thu May 02, 2013 5:36 pm
by dexta roadless
I guess your oil pressure switch is playing games with you
Re: Wiring problem
Posted: Thu May 02, 2013 10:52 pm
by Vulgunx
Ok Oil pressure switch working as it should be will keep you posted about the dynamo problem :) just need my friends amp tester, the dynamo should be ok since it was recond about a month ago :S
Re: Wiring problem
Posted: Fri May 03, 2013 2:08 am
by scoobyjim
What was it then
Re: Wiring problem
Posted: Fri May 03, 2013 1:28 pm
by Vulgunx
Im not 100% sure must be a dicky wire or somthing but there was a washer there that could of been the problem :)
Re: Wiring problem
Posted: Sun May 05, 2013 4:59 pm
by Vulgunx
Had the tractor running today for about an hour and went to go shut her off lowerd the revs so she was just ticking over and the oil pressure lights flashes? start highering the revs and the light goes off?
Re: Wiring problem
Posted: Sun May 05, 2013 5:37 pm
by Jerry Coles
I think you want to get a good idea of your actual oil pressure. Private Message (PM) me with your address and I'll loan you my oil pressure gauge.
You can then monitor the pressure over the rev range.
Have you done anything to the oil system?
Re: Wiring problem
Posted: Tue May 07, 2013 12:07 am
by PghBill
If the light comes on at idle and goes out as you increase the RPM's it's working as it should.
Re: Wiring problem
Posted: Tue May 14, 2013 12:14 am
by Vulgunx
Just like to tell everyone i have fixed the issue with the lights, on the dynamo side the lights were earthing to the metal even tho i got the ones with the rubber coat over them so i have changed them for a different kind so thats all good my oil pressure still needs to be tested but should be ok :)
