Blue Battery Leads
Spoots1
Blue Battery Leads
Does anybody know where to get blue battery cable? All I can find anywhere is red or black! Have seen plenty of restored dexta's with new blue cable's so someone must supply it? Any ideas Guys.
1963 New Performance Super Dexta (in bits)
1981 John Deere 2140
Re: Blue Battery Leads
Why dont you just wrap them in blue insulation tape?
Or you could get some neutral cable, but it would have to be tri-rated, like the kind you find inside distribution boards etc
marcusgs
No idea where you could get blue cable from, however you could get black, and sleeve it with some blue heat shrink tubing from here..
http://www.ebay.co.uk/itm/1mm-15mm-Heat ... 23299654ae
Much more professional and long lasting than insulation tape.
Just slide it over, and heat it gently with a blowtorch or heat gun until it shrinks around the cable gripping it tightly.
Mark
Spoots1
Thanks for a your suggestions guys, I have a few options now so will get something sorted!
Spoots1
Have managed to source blue battery cable, good old ebay! When I looked there a couple of weeks ago there was nothing, but checked again yesterday and low and behold I found some!
For anyone else looking, its 247supplieslimited who are selling 10mm blue battery cable at a very reasonable rate per metre.
Spoots1
Hi again guys, I received my blue battery cable through the post the other day only to be disappointed! It is only 6mm in diameter??? I contacted the sellar who informed me that the nominal cross-sectional area is 10mm squared! So I have had to return it and get a refund. So the search still continues!
wfillingham
Personally, I think the blue heat shrink is the way to go... in the past i repaired a satellite nav system and heat shrink was actually superior to the original material of the cable.....
Sorry about my not very 'professional' suggestion, were the battery leads not black from factory, or were they blue?
Nick,Nick wrote:Sorry about my not very 'professional' suggestion, were the battery leads not black from factory, or were they blue?
Don't go gettin your knickers in a knot.
Don't ever be afraid to post.
Bill
marcusgs
Sorry Nick, wasn't meaning to upset anyone with what I was saying.
I was purely meaning that insulation tape tends to become brittle with the heat from the engine and then cracks and breaks off, where as heat shrink doesn't.
Regards,
Regards,
Mark
Dont worry I wasnt upset! I have seen some heat resistant blue fabric stuff which may have also done the job, but heat resistant sleeving seems the quickest and easiest thing
Dextas and Super Dextas in Canada started out with blue cables.Nick wrote:were the battery leads not black from factory, or were they blue?
(Well, atleast the ones I have seen....)
Cheers,
Les
Spoots1
I didn't mean for things to get heated! Blue heat shrink is what I am going to try as I already have some left over black cable from another tractor. Thanks for everyone's suggestions.
