1. Washer Injector (body to head) Sealing (9/16 x 13/16 x 1/16) PN 118358-ES. Need 3, SPAREX does not show them. Where can I get them?
2. Sparex # S.42230 Gasket - Combustion Chamber 81803686 or 957E6K003 2 (EZ find)
3. Washer, 21/64 ID 1/2 OD x 1/32, PN 118357-ES Where can I get them, these are the injector return line seals above injector?
The main reason, I am posting this, is if I am having problems, I am sure there are others in US, and these are common parts, but not consumables. Replace once, and unless you mess with it, never again till rebuild. None of the sites have the washers here in the US. Dealer was no help, no longer serviced. Can anyone help with a source? Sources? Sparex, bareco #?
Wayne
Dexta Parts
Dexta Parts
Re: Dexta Parts
these parts are not for my Normal Dextas on the farm.
I recently bought two MORE super Dextas, and this is for the first one, which was initally locked up, but after two weeks of penetrant, is loose, runs, has little or no blowby, has all the good sounds at mid and high rpm, but intermittenly has sloppy idle, and cranks but won't start intermitenly, but pull start 3 feet and its running. Exhaust is clean, pulls good. Saw a bubble on one of my head cumbustion chamber gaskets, so that will be replace. After it warmed up, no bubbling. Have a couple missing injector return line washers, and I must have pulled those injector 5 or 6 times while troubleshooting and freeing. I am almost positve the missing washer is the root cause of my sloppy idle and poor starting.
both these are such clean tractors, hardly any rust, the second has almost no dents in tin, and has all the chrome options.
I have checked every site here I can think of, with no result, and google search of fordson part numbers show no return. Any help is appreciated.
Wayne
Virginia, USA
Wayne
Virginia, USA
Re: Dexta Parts
Hi Wayne, think you should try Agriline website here in U.K. i'm almost sure they have what you want
Re: Dexta Parts
Here is the problem with these parts. No one sells them in bulk, and the cost is HIGH. $5.99 for the injector body crush washer, $17.99 for the cumbustion chamber washer, and $4.99 for the return line bleed nut sealing washer. Is there a link to the Agriline website?
1. Washer Injector (body to head)Sealing (9/16 x 13/16 x 1/16) PN 118358-ES.
BARECO part number B224
Massey Ferguson part # 0920113
SPAREX # S.6372 another page in their book shows this a S6371
5310-99-431-0405 WASHER,FLAT
0821PE09 20113 U1278 MINISTRY OF DEFENCE NAVY
0920113 K3879 MASSEY FERGUSON MANUFACTURING CO LTD
0920113 K5436 PERKINS ENGINES CO LTD
0920113 K5609 TEREX COMPACT EQUIPMMENT
0920113 U3888 POWER DIESELS LTD
18AA417 U1725 MINISTRY OF DEFENCE AIR DOMESTIC R FERENCE NUMBER USE ONLY
2411 K3879 MASSEY FERGUSON MANUFACTURING CO LTD
2411 K5609 TEREX COMPACT EQUIPMMENT
2411-131 K5436 PERKINS ENGINES CO LTD
2411131 K5436 PERKINS ENGINES CO LTD
61PK10423 U1725 MINISTRY OF DEFENCE AIR DOMESTIC R FERENCE NUMBER USE ONLY
990615 K4733 HYSTER EUROPE LTD
X3XCPK0920113 U1269 MINISTRY OF DEFENCE - DEFENCE LOGIST S ORGANISATION DLO
3. Washer, 21/64 ID 1/2 OD x 1/32, PN 118357-ES These are the return line washers you bleed atop injectors.
New Holland Part # 118357ES $4.33 Amazon 7 left in stock
316159A1 is a replacement part from FNH - cost is $4.54 at partsspring (I have 5 Dextas now, and let's say I just ordered 12 ($59.88) The original Dexta parts book list the need for three. Each tractor I have has 6, one on top of the nut to banjo and one on bottom, so I could do 2 tractors. See the price is too high).
Re: Dexta Parts CASE CLOSED
Parts ordered. Case closed.
Wayne
Wayne
