Fuel Connections
Posted: Tue Sep 03, 2013 8:37 pm
				Just recently our Dexta has been suffering from repeated air locks at the filter and the injector pump. One of the connections at the lift pump has had a weep and on further inspection is inconsistent with others. Here's a photo...
The flow to the pump (nearest in photo) is suspect, and I think this joint is allowing the lift pump to draw air, it doesn't close up fully before the thread bottoms out. Should I simply remake the connection in the same manner as the other, I presume this is just an olive. I have measured the pipe at approx 6mm OD, what size olive should I look for?
Just after a second opinion before I look to remake this joint in my process of elimination...
Thanks for any help, Sam
