				What is this for?
				Posted: Tue Sep 10, 2013 8:40 pm
				by Cvans
				I've looked in the owners manual and can find no reference to this. Runs between the 3 point control and the hydraulic control on top of the transmission.
Any ideas what it is for?
				Re: What is this for?
				Posted: Tue Sep 10, 2013 10:13 pm
				by PghBill
				It's the hydraulic flow restrictor. Controls the up/down speed of your 3 pt. As you move the lift control up and down it also operates the flow restrictor. The more you move the control lever in the Quadrant the faster you lift operates.
				Posted: Tue Sep 10, 2013 10:29 pm
				by Cvans
				Thanks for the reply. Makes sense but the only time the lift control hits the linkage to the flow control is when the handle is all the way up.
Whats the knob do? Would have been nice if they would have explained it with a diagram in the owners manual. I have the manual that came with
the tractor when it was new. Maybe I should look at it again now that I know what it's function is.
				Posted: Tue Sep 10, 2013 10:42 pm
				by dexta roadless
				The knob is ment to adjust the speed of lifting. So when you keep the plough or similar in the ground you can adjust how quick the3pl responce to corrections. When you want to lift it out of the ground you pull the handle right to the top wich will move the linkage and then you lift with maximum speed. Hope this is clear with my kind of english.
				Posted: Tue Sep 10, 2013 11:21 pm
				by Cvans
				Your English is very good. It's my simple mind that gets in the way.
Thanks for your reply and I think I have a good idea of how it works now. Just going to go out see how it works.
				Posted: Wed Sep 11, 2013 11:34 pm
				by tom lad
				hi
the black knurled knob should screw in and out , like a bolt , as it screws the arm rotated , if u understand me
the coil spring on the quadrant end pulls it back to slow .
very useful if its all working , or just leave it in fast .
screwed in is fast , there should be a F  and S   cast in the cover .
				Posted: Thu Sep 12, 2013 1:20 am
				by Cvans
				Thank you all for the help. I haven't had time to play with it yet but I will give it a try.
				Posted: Tue Feb 11, 2014 8:50 pm
				by Beauwh
				What is the round silver knob also?
				Posted: Tue Feb 11, 2014 9:18 pm
				by Timeee
The round silver knob (should be black) is the Auxiliary Service Control.  Push it in for the hydraulic arms to operate.  Pull it out and the ram cylinder circuit will be isolated and the hydraulic pump will deliver oil to the external services, usually a trailer tipping pipe, or to power an external remote hydraulic cylinder.  Sometimes they become seized through lack of use and the (bakelite?) knob is usually butchered in an attempt to free it off;  Hence the metal one I presume.  Unless someone knows different..........
Tim E
				Posted: Mon Mar 24, 2014 5:38 am
				by Cvans
				When I purchased the tractor the knob was missing so I machined one out of aluminum. Not original but it works.
Sorry it took so long to reply but my other computer died and I'm just finding my way back to some of the forums.
				Posted: Tue Apr 01, 2014 1:20 am
				by Beauwh
				Is that a hydraulic line coming out of the plate  in the picture? If so is there a return line somewhere. My super dexta has the same top plate as yours with the flow restriction knob. Im wanting to add a hydraulic remote to it so i can pull a haybine. It doesnt matter if it is paired with the 3pt lift or independent. Im trying to figure out what i need to do to get this done.
thanks
				Posted: Tue Apr 01, 2014 8:38 pm
				by sky blue
				there is no return line just remove the oil filler nut on back axel
an get some sort of adaptor to screw in to
    to take a return
				Posted: Wed Apr 02, 2014 12:10 am
				by Bensdexta
				tom lad wrote:hi
Doesn't have any effect when hydraulics are in Position mode, does it?
				Posted: Wed Apr 02, 2014 7:20 am
				Yes, it controls any oil flow in the system whether it be taken from the lift via the ASC or used to operate Draft or Position control. We used to use the flow control to control the speed of the hydraulic motor on Tasker Spreaders.
				Posted: Thu May 22, 2014 12:49 pm
				by Kipperwood
				Hi I'm new to this forum but thanks to some excellent posts I have just repaired my hydraulic lift. My Dexta has the control knob on it but not the linkage. As I will not be needing it for anything more than paddock care, I will leave it set to fast. Before I set it up I downloaded a clip of it working to YouTube, if you type in the following you might be able to find it " fordson dexta flow control hydraulic lift" . The problem with the lift was the stuck un-load valve. Thanks
