I'm in the process of purchasing a used New Holland 757c 3 point backhoe and would like to use it on the Dexta. Would it be possible to run it off of the tractors hydraulics? I have one hydraulic line running to the rear of the tractor and need to know where the return line should be piped to.
Thanks for your help.
Dexta Backhoe?
Dexta Backhoe?
Chris
Re: Dexta Backhoe?
You would dump the return line into a fitting at the filler plug. I would think the dexta hydraulics would have to little flow to get some decent speed on the controls on the backhoe.
frode
1957 County MarkIV Crawler
1964 County Super-4
1967 County 654
1977 County 7600-FOUR
1964 County Super-4
1967 County 654
Double post
Double post. Ignore please
Chris
Re: Dexta Backhoe?
Filler plug sounds good.I would think the dexta hydraulics would have to little flow to get some decent speed
If it is slow at first that's fine as I have never run one of these things before and the slower it goes the less damage I will do.
There must be some flow out of this pump as it lifted the cycle mower almost too fast. But that was only one cylinder at a time.
Chris
