				Dexta Backhoe?
				Posted: Wed Sep 11, 2013 9:01 pm
				by Cvans
				I'm in the process of purchasing a used New Holland 757c  3 point backhoe and would like to use it on the Dexta. Would it be possible to run it off of the tractors hydraulics? I have one hydraulic line running to the rear of the tractor and need to know where the return line should be piped to.
Thanks for your help.
				Re: Dexta Backhoe?
				Posted: Wed Sep 11, 2013 9:03 pm
				by frode
				You would dump the return line into a fitting at the filler plug. I would think the dexta hydraulics would have to little flow to get some decent speed on the controls on the backhoe.
				Double post
				Posted: Thu Sep 12, 2013 1:23 am
				by Cvans
				Double post. Ignore please
				Re: Dexta Backhoe?
				Posted: Thu Sep 12, 2013 1:25 am
				by Cvans
Filler plug sounds good.
If it is slow at first that's fine as I have never run one of these things before and the slower it goes the less damage I will do.
There must be some flow out of this pump as it lifted the cycle mower almost too fast. But that was only one cylinder at a time.
