				Hydraulic system question
				Posted: Fri Sep 20, 2013 11:09 pm
				by Cvans
				I've done a search on line and here and am unable to find the information.
What is the is the hydraulics system flow capacity and the relief valve setting?
Thanks for your help!
				Re: Hydraulic system question
				Posted: Sat Sep 21, 2013 7:08 pm
				by Bensdexta
				See Fordson Dexta Workshop Manual (Section8) for Hydraulic System, page 34
15.0 L/min @ 1550rpm
Relief pressure 2100 - 2300 psi.
				Posted: Sun Sep 22, 2013 4:24 am
				by Cvans
				Thank you for the reply. I looked through the manual section above but didn't see that information.
I'm looking at moving the backhoe to the 850 Ford and I will need a pump. Your reply will help me size that pump.
