Which way does your mushroom swirl?
Posted: Tue Sep 24, 2013 7:11 pm
				Just realised that my repro mushroom is an awful copy of my original.
Correct me if I'm wrong, but pretty sure the mushroom is designed as a swirl-tube air cleaner (ie dust ejector). IE incoming air is swirled to throw dust outwards and out through the ejector vents at the top. Clever stuff if it works!
But see comparison of the gills on the underside. Apart from being poorly formed, the gills on the repro unit(right) swirl the incoming air in the clockwise direction when seen from below, the opposite way to the original.
But the dust ejection vents at the top, face the same way on both, ie the wrong direction to eject dust for the repro. Notice also the vents on the original are at the top of the cone and the cone is higher, presumably Ford did this for a reason.
And the original mushroom(below) has swirl vanes in the downpipe, the repro has none!
All in all a very poor repro unit.
So out with the repro and in with my original. I have straightened it and cleaned it up, should look good when painted !
So once again beware of repros - unless anyone has come across a better unit?
