Proven again what an amateur farmer I am again. Ran the tank dry.
What's the correct procedure to get rid of the air in the fuel system?
Running dry
Re: Running dry
First of all add some diesel in the tank. next: open the bleeder on the top of fuel filter and pump with the handle on feedpump.when all the air is gone there, close it and open the bleeder on the main fuelpump and continue pumping. once the air is gone close it. If you have a cold start button, press it and start cranking until it fires. you can ease it abit by loosening the Hp pipes at the injector end to let the air out, but it's not necessary.
6o Dexta Roadless
62 Dexta
63 Super Dexta
75 Shilter UT
62 Aebi
62 Dexta
63 Super Dexta
75 Shilter UT
62 Aebi
Re: Running dry
go into dexta manual part three on the net
