- new battery leads and starter lead
- overhaul starter motor and new rubber boot
- overhaul generator
- repair leaks in radiator, new set of hoses and drain cock
- panel beat the radiator shroud
- new thermostat (there was none)
- new water pump (I'm planning on flipping the old brass backing plate over to give unworn and non-dezincified surface - is that kosher?
- new fan-belt
Questions:
- all my previous automotive thermostats have had a bleed hole. The new Sparex one doesn't. (Why not, should I drill one?
- is there an easy technique for getting the bypass hose installed?
- bought a new temp gauge (Sparex) too. Totally UNEXCITED by the prospect of loosening all the tank screws to squeeze the sender unit down through the small hole. What is the correct routing from there on?
Hoping like heck after all this auxilliary stuff the 'heart' of my dexta is good!
Completely unrelated:
tonight got to play on the major. Drove 1 km down our (mercifully) quiet road to neighbours. Pretty scary in top gear. Used loader to lift and place large hardwood gatepost. Neighbour suitably impressed. Sneaked home (less scary 5th gear, no lights, no cars - phew!). Extra bonus - not running out of petrol in dark, not running out of spark (don't think generator is charging).
