Dating my Dexta
Posted: Sun Dec 01, 2013 8:24 pm
by welderpaul
I've read the threads on here regarding dating my Dexta, but i'm still unclear. Can anyone help???? :?
Serial number 957E7005
Engine number (stamped number) 1470209
Clutch housing M11D Also stamped number next to flywheel peep hole 957E7505B
Gearbox L1D
Rear end L21D
Lift cover - Can't read
RH rear axle M11D
LH rear axle M6D
Any help much appreciated! :buddies:
Re: Dating my Dexta
Posted: Sun Dec 01, 2013 11:33 pm
by Bensdexta
welderpaul wrote:Serial number 957E7005
Gearbox L1D
Rear end L21D
RH rear axle M11D
LH rear axle M6D
The first no you list is not the serial no, which is stamped vertically near the flywheel peep-hole.
Your tractor was build about Oct 1960. The engine # is consistent with this. Do you have your engine cast code (see sticky ^)?
Re: Dating my Dexta
Posted: Mon Dec 02, 2013 8:59 am
Serial number is here, as Ben says.
Re: Dating my Dexta
Posted: Mon Dec 02, 2013 8:23 pm
by welderpaul
Thanks very much Ben/Brian. The code on the engine is L300. October?
Re: Dating my Dexta
Posted: Mon Dec 02, 2013 8:59 pm
by Brian Cox
the serial no. normally starts with 09A or 09B , C or D , do you understand what I mean? :?
Re: Dating my Dexta
Posted: Mon Dec 02, 2013 9:03 pm
by Brian Cox
hello i'm back, have a look on Brians Dexta Register page and you will see what I mean :beer:
Re: Dating my Dexta
Posted: Mon Dec 02, 2013 9:28 pm
by welderpaul
Brian Cox wrote:the serial no. normally starts with 09A or 09B , C or D , do you understand what I mean? :?
Engine serial number? Just had a look, no number of that format on there. Am i looking in the right place? :oops:
Re: Dating my Dexta
Posted: Mon Dec 02, 2013 10:23 pm
by Bensdexta
You have the correct nos, exc the last digit of your tractor # is incorrect - prob 8 not B?
Assuming above, your data is:
Tractor # 957E75058 (NB prefix 957E is correct for 1960) clutch cast code M11D (11/10/1960)
Engine # 1470209 (looks an Oct 1960 no)
Engine cast code L300 (30/10/1960)
So all your nos look spot on on my graphs. Your tractor was probably assembled in Nov/Dec 1960.
Does she have a road reg?
Re: Dating my Dexta
Posted: Mon Dec 02, 2013 10:38 pm
by welderpaul
Just been out in the cold again...
The number hand stamped next to the peep hole is 957E67439.
The number 957E7505B is a cast mark on the opposite side to the hand stamped number.
That will teach me to scribble numbers down on oily bits of paper. Does this change anything?
She doesnt have a road reg.
Re: Dating my Dexta
Posted: Mon Dec 02, 2013 11:06 pm
by Bensdexta
welderpaul wrote:The number hand stamped next to the peep hole is 957E67439.
That tractor # fits my graph even better, so still a late 1960 tractor. :wink:
Re: Dating my Dexta
Posted: Mon Dec 02, 2013 11:16 pm
by welderpaul
Thank you very much for that. Great to know the age of the old girl. :wink:
Re: Dating my Dexta
Posted: Tue Dec 03, 2013 8:43 pm
by Brian Cox
Hi Welderpaul, me again, I was on about the tractor serial no., this is stamped on the flange between the engine and gearbox, and yours will probably start with 09A :roll:
Re: Dating my Dexta
Posted: Tue Dec 03, 2013 8:55 pm
by Bensdexta
Brian Cox wrote:... yours will probably start with 09A :roll:
09A is a late 1961 tractor - I've got one! :wink:
Re: Dating my Dexta
Posted: Wed Dec 04, 2013 8:42 pm
by Brian Cox
sorry Paul, I'm a numptie this time, fools rush in and all that jazz. Dexta 1960 was 957E 44432 to 71920 :eyes:
