Bens Dexta - 2
Bens Dexta - 2
Following on from my previous "Ben's Dexta - 1" thread, we've removed the front axle.
We tried to turn the engine with a 3/4" drive+bar on the pulley nut. The nut turned but the crankshaft didn't, so conclude the engine is well seized.
We drained over a gallon of water + some oil from the sump. Removed the injectors and poured in patent cocktail - ATF, diesel and Coca Cola.
It appears that an engine rebuild is called for. I have had a favourable report from a friend who's rebuilt several dextas of Areon Engines Services, Felinfach, Lampeter, Dyfed. Can anyone second this, or suggest another good value place for either a block rebuild or a full engine rebuild, preferably in the midlands/Wales area?
Any advice appreciated, thanks,
Ben
Ben
Engine rebuilding - WHY REBORE?
My engine is seized and a rebuild is in the offing.
One engine shop who rebuilds Dexta engines said their usual practice is to fit new but oversize liners, then re-bore to match the new pistons and rings. I'm just wondering why they would do this? Is it not possible to get matching liners and pistons? Perhaps I should ask them!
All the best,
Ben
All the best,
Ben
Unfinished liners
Mike,Mike Kuscher wrote:The Dexta is different !
The liners are unfinished. They must be fitted into the block first, then finish bored to size, otherwise you will wreck all your hard work.
Mike
Many thanks for the explanation. So for the Dexta finish boring after fitting is standard. Interesting that this is not the case for the Major liners.
All the best,
Ben
FIRST REFURB - INJECTORS
Completed our first refurb today - the injectors. Before, none were working:
After servicing by Peter Strong, Grazeley Green, nr Reading who is highly recommended for fuel injection servicing.
Just need a serviceable engine to put them in now!
All the best,
Ben
All the best,
Ben
Casting Code
I'm gathering info to register my Dexta, but am having difficulty interpreting the casting code on the right back axle. Below is a photo of the rear side of the right back axle:
Below is a close up of what I believe to be a casting code:
Can anyone help me decipher this casting code, as it appears to read 22 J 4, which I don't think makes any sense according to the info on the website?
The other casting codes which I have been able to decipher all end in the letter F, example below from the gearbox (L20F):
which I think agrees with the tractor serial no which starts 09A (Nov-Dec 61). The buff reg doc shows that the tractor was first registered in Jan 1962.
Any help appreciated!
Many thanks,
Ben
Many thanks,
Ben
The casting code is J4D so that gives July 4th 1960. The gearbox is September 20th 1961 so the axle castings had been hanging around for over a year which is possible. Or they could have been replaced though as they are both the same I would doubt it.
Brian,Brian wrote:The casting code is J4D so that gives July 4th 1960. The gearbox is September 20th 1961 so the axle castings had been hanging around for over a year which is possible. Or they could have been replaced though as they are both the same I would doubt it.
Thanks. But what is the '22' that appears to be at the start of the axle code?
Thanks again.
Ben
Yes I'm happy that is what the gearbox code is (3rd image). Still puzzling over the axle code - I'll try to clean it up better and also try to read the left axle, but it is more corroded.Mervyn Spencer wrote:To me that code reads L20F? Is it possible to scratch a bit more around that area?
All the best,
Ben
L20F is the September code on the gear box.
The "22" is not part of the Ford coding system so can be ignored.
All the casting codes are given on the first page of this site in the information section.
Axle casting code
Brian,Brian wrote:The "22" is not part of the Ford coding system so can be ignored.
On re-reading the info on casting codes ^, I see it says that the rear axle casting code is located on the FRONT side of the axle. So please can you confirm that this code
is not relevant to dating the axle? Do I need to find another code on the front of the axle?
Many thanks for you help.
Ben
Ben,
That is the casting code. There is no code on the front of the axle. The code is situated on the back and can be seen from the rear. Yours is just poorly formed or rusted off.
Rear Axle Casting Code
Brian,Brian wrote:Ben,
So you think my code is J 4 D and the '22' is irrelevant?
Sorry to labour this - it's all a bit puzzling! Hopefully the DVLA man won't cause probs if/when he wants to look at it. I would rather have my ducks in a row!
Thanks again,
Ben
He will not be concerned about axle codes, he is more interested in the serial number and whether it is a tractor or not.
You need to send pictures of the tractor and pictures of the serial number. They will prove your date. The axles are removable and could have been fitted at any time. But the serial number should be on record as that is the identity number and can date the tractor too.
Hi Ben,
It depends on the person that deals with your request from the DVLA. When I registered my Dexta I sent up a complete set of photos showing all the casting codes and serilal number as proof of year but they still sent a chap on a 100+ mile journey to check them out, he was only with me for 10 minutes if that.
However they were very quick in dealing with my application I must give them that credit and Thomas Andrews was also excellent.
Regards,
Barry
Regards,
Barry
Rims for Rear Wheels
I've removed the rear wheels:
They've now been stripped down by our local agricultural engineer who says the centres are OK but the rims are too badly corroded and weak.
So it looks like we need new rims unless a pair of sound 2nd hand wheels come up.
Does anyone have advice on where best to get a pair of rims (the tyres are 12.4s)?
Thanks,
Ben
Thanks,
Ben
Stripped the rear wheels:
Need to replace the rear rims.
Old 28" rims measure 9" internal bead width.
Advice appreciated on whether to get new 9", 10" or 11" internal width rims. Plan to keep the 12.4x28 tyres.
Your advice appreciated.
Ben
Ben
