Opening the simms pump
How do i open my simms pump since ive been told that it will help some more speed out of my dexta
									Owner of a 1961 fordson dexta restyled model
						Re: Opening the simms pump
If you open up your injector pump for any reason you need to take it to a specialist. I'd advise against that.
What is wrong you don't have enough power? How many RPM's do you have?
You can set up the RPM's to get more power is the only way I can think of.
I hope some of the experts read this and can help you further with your problem.
See ya
Mark
						Mark
