in need of picture of idle screew
deboutdors
I live in Texas USA. and I am in need of some help. I had my Dexta put in the shop to replace the clutch and it came back with to high of an idle. I need to know where I can find it so that i can adjust it myself. Also my lift is very weak and wont stay up it always drifts down. I have read about the worm pin just not sure if that will fix it. Thanks Debbie
Re: in need of picture of idle screew
Debbie,
The idle screw is the one to the right of the red arrow (which indicates the throttle linkage) in the pic below:
If you set the throttle in the fully closed position, you will see that the throttle arm (attached to the throttle butterfly axle) is touching the idle stop - as it is in the pic.
deboutdors
Thank You Bensdexta , We now think it the fuel injector pump. Ordered a new diaphrapm for my jan 1962 Dexta.
