oil filter
Posted: Mon Mar 31, 2014 6:57 pm
				hi i just thought id share this with you all , ihad changed the oil an filter last sept as per usual
had nt done a lot with her since about 20hrs , well itook her out for arun and happily driving along
when the oil light came on, i killed the engine right away, the whole side of tractor was covered in oil,
the ruber seal had been cut into with the housing of the filter and had spewed the oil out. this has happened
i see on here before, is there a fault with the seal or have i been heavy handed wthe 5/8 when tighting up the nut
lucky this time i caught it in time without the oil warning light things could have been very different, im now
going to get me a spin on type filter as i cant trust this origanal filter or myself when tighting it up, let others be weary
of this when changing the oil and filter
   sly blue
