Hi All,
Does anyone know what thread the fuel tank mounting screws are on a dexta? I think they are 7/16" UNC!
Dexta fuel tank
oehrick
Re: Dexta fuel tank
Nope, but someone else is bound to, you have asked the right bunch for detailed information
Welcome aboard
Welcome aboard
Re: Dexta fuel tank
I wil replace most bolts with metrica bolts and nuts
only the places were that is not posibole stau original
Re: Dexta fuel tank
My 1962 Dexta has studs screwed into the 3 holes in the bottom of the fuel tank. It is 7/16 inch UNC going into the fuel tank and 7/16 inch UNF at the other end of the stud, to allow a nut and washer to be screwed on to fix it down to the tank mountings. It makes it a lot easier to locate the fuel tank and the clearance between the top of the lower dash and the rear mounting allows you to get the nut on, rather than having to remove it (the lower dash) to get a screw in.
Tim E
Tim E
