				top link rocker bracket
				Posted: Mon Apr 21, 2014 7:41 pm
				by Brian Cox
				my top link rocker bracket has a great deal play, must be worn out. Thinking of replacing it, does the bush just chap out ?
				Re: top link rocker bracket
				Posted: Tue Apr 22, 2014 5:47 pm
				by marcusgs
				Brian,
To make this job easier, you really need a stick (arc) welder.
If you run a bead of weld through the inside of the bush from one side to the other, let it cool, and then it should come out, with a little persuasion
Simply whacking it with the hammer will most likely result in a snapped off lug from the top link casting
Hope that helps.
				Posted: Tue Apr 22, 2014 7:54 pm
				by Brian Cox
				cheers marc, will give it a try
				Posted: Mon May 12, 2014 9:04 pm
				by Brian Cox
				new bracket arrived to-night, needs a coat of paint, then will try to remove the old one. Will let everyone know the outcome
				Posted: Thu May 15, 2014 5:38 pm
				by tom lad
				I pulled my bushing out , or what was left of it ,with a long HT. bolt / threaded bar used with spacers as a puller , plus a bit of heat .
replaced with two bushes , I think they were adapters from cat 1  to cat2 ?  the agri dealer had them , two were the perfect length / width.
				Posted: Thu May 15, 2014 8:12 pm
				by Brian Cox
				my panel beater son has had a go without success, he will try again this weekend using a little heat
				Posted: Thu May 15, 2014 11:21 pm
				by tom lad
				I think I posted pictures on here  of the puller I made  a year or so ago ?
I can do it again if it helps ?
I had cut off the rocker , bad corrosion of the bush , so I was only pulling the bushing out of the casting / back axle .
hope that makes sence ?
tom
				Posted: Thu May 15, 2014 11:28 pm
				by tom lad
				Posted: Tue May 20, 2014 8:06 pm
				by Brian Cox
				Thanks everyone for your help
  job done, a little bit of heat, knocked it out with a hammer and a socket
				Posted: Fri May 23, 2014 9:12 am
				by tom lad
				well done
