fuel pump removal
Posted: Mon Jun 30, 2014 2:29 pm
				Hello
I wish to remove the fuel injection pump to be able to clean up and paint behind it and the pump its self. Reading the manual pdf I think it is clear to me how to reset the timing when refitting it, but I wonder if there is any other maintenance I should be doing while it is off. the manual refers to a pnuematic diaphram and air filter. Mine seems different so maybe I don't have to do that? see picture.
I will of course seal the ports as best I can with tape while the pipes are off.,
Ian
Ian
