				which way up does the spindle thrust bearing go?
				Posted: Sat Jul 19, 2014 2:07 pm
				by Johnmcm
				Forgive the numpty question but which way up does the bearing go?
I'm using this product.
http://www.agrilineproducts.com/Catalog ... 39f4d9956f
Also, do I grease them?
Thanks for your help.
				Re: which way up does the spindle thrust bearing go?
				Posted: Sun Jul 20, 2014 10:12 am
				by Johnmcm
				Ok then, does it matter?
Does a generic thrust bearing have a 'load bearing' face?
Ta
				Posted: Mon Jul 21, 2014 12:11 am
				by oehrick
				Hi John,
I don't know the bearing or app (or if the linked pic is accurate) but a straight thrust race which takes no radial load is in theory omnidirectional i.e. both faces must by definition take the same load - although this appears to have an integral seal so presumably the seal o/d has to seat in a housing and therefore can't rotate
 if not oil fed presumably it needs some sort of lube on installation.
Hope this makes some sense and helps if not, defining which spindle on what might bring a bit more help
If not RTFM applies !!
				Posted: Mon Jul 21, 2014 10:23 am
				by Johnmcm
				Thanks for taking the time to reply. I think that makes sense.
I will grease the bearings and see how we go.
Many rhanks
				Posted: Tue Jul 22, 2014 12:45 am
				by oehrick
				Sorry I was a bit vague John, if you'd given a little more info on the application you might have needed a shovel to dig yourself out of the replies as folks hereabouts are not slow passing on help, info, good wishes or sympathy depending on the problem
Hope the job goes well
				Posted: Tue Jul 22, 2014 8:16 am
				by russelm
				Looks to be the same bearing type I used on mine in which case they are symmetrical so can be fitted either way.
				Posted: Tue Jul 22, 2014 9:55 am
				by Johnmcm
				Sorry if I was vague. They are the front axle kingpin/spindle thrust bearings.
One face is grooved, the other is not.
Thanks for the help chaps
				Posted: Tue Jul 22, 2014 10:34 am
				I have just taken a new thrust bearing out of the box and it is a metal cup shape with a plain hard surface. The metal cup goes into the axle with the plain hard surface facing downward onto the stub axle.
Top, towards axle.
Side View.
Bottom towards stub axle.
				Posted: Tue Jul 22, 2014 11:43 am
				by Johnmcm
				Yes, thanks Brian. Hopefully that will help others down the line as well as me now.
That's the beauty of a good forum.
Many thanks
