				Southern Tractors Fuel Primer
				Posted: Sat Aug 02, 2014 11:21 pm
				by agroman
				I have just received a fuel primer tap from Southern Tractors. In the box there is a warning notice about only using clean fuel, otherwise it will damage the primer. Question is, is the in tank filter adequate for this or should I look to remove tank and use a sealer kit? for sure there will be rust and crap in the tank.
Also I have a fuel line pipe from Agriline to fit between fuel primer and manifold. The pipe flare on the primer end is poor and the pipe is loose when pipe union is tight. Is this a case of cutting and re flaring the pipe to give a tight fit or should I use a 1/4" olive + flare?
				Re: Southern Tractors Fuel Primer
				Posted: Mon Aug 04, 2014 9:16 am
				by sky blue
				hi, on several post going back there has been bad reports on the aftermarket
 fuel primer with them leaking mybe this has been sorted out by now ,
 but mybe this is a get out cluase for s , if the pump is  fit for purpose as
 it should be then why should one have to take the tank out to replace a
primer pump
 phone  s up and ask them will they stand by
 the product before fitting and then you wil at least get you hard earned back
 if its not up to the job,   let us know how  it works out, as a good fuel primer pump
 would be worth its weight in well not gold but mybe  brass
				Posted: Mon Aug 04, 2014 1:42 pm
				by Johnmcm
				Do you have a link to the fuel tap primer you refer to?
Ta
				Posted: Mon Aug 04, 2014 8:55 pm
				by sky blue
				hi John,sorry  cant remember was a while back ,but i think that they had changed
the f/p tap twice before eventually got one that did the job , if the are
 still reading the posts and see this mybe they could come in an let you know of their
experiance with  the taps
				Posted: Mon Aug 04, 2014 11:23 pm
				by Johnmcm
				Hi sorry sky blue, I meant the original post.  Is Southern Tractors the same as Southern Counties Tractors?
Ta
				Posted: Tue Aug 05, 2014 8:39 am
				by sky blue
				icouldnt say but  the taps probley all come from the same sorce in turkey
 or where ever , doesnt really matter who supplies them, thats why a
lot of tractor restorers will go for the old orignal and try to bring them back to life
 not to say yours may be a good one, but just to be sure the warning in with it isnt a
cope out clause, to many have got stung by these money making suppliers with no
come back if the part isnt fit for purpose,  [ rant over for to-day
  mybe im gettig old and crabed
 with age
				Posted: Tue Aug 05, 2014 2:38 pm
				by Bensdexta
				You could always make your own.
My Stefan tap works great!
http://www.fordsontractorpages.nl/phpbb ... f=3&t=2079
