is this the heater on my super dextra
oldcharlie
Re: is this the heater on my super dextra
yes that is the heater ,screw it out and test it on abattery
put the thread bit on the neg termnal and touch the part were the wire goes on with a
spanner or piece of copper wire from the positive termnal
the coil inside the heater should come up bright red if its working
oldcharlie
Thank you very much! i will check it out and if it don't work will try to find a new one.
