seat for super dexta
tom lad
Post by tom lad »
think my s dexta due a new seat , before this one rots thru :oops:
I fancy a sprung one , any recommendations please ??
sky blue
Re: seat for super dexta
Post by sky blue »
hi i have a standered type ford one on my s/dexta, fitted on fine
just uses the same two screw holes as old one, and a comfy drive :D
tom lad
Post by tom lad »
hi
do you mean the steel pan type like agriline sell ??
sky blue
Post by sky blue »
no the ford modern type seat, it is the type with the damper rod in the
back for suspension , it comes with a plate which screws onto tractor the seat then
slides into this, it can be adjusted foward or backwards to suit driver,
agriline do them as the ford 000s seris seat
tom lad
Post by tom lad »
Cool
I'll have a look
Ta
Post by Bensdexta »
Deliberated long and hard over a seat.
Eventually decided on an original (repro) style one. Not the cheapest option by far. But has advantage that it will tip up, good as I quite like driving standing up - easier to watch for rocks when topping etc. Also runs the rain off!
Do you fancy arms or not? Remember to check height etc so you can reach the peddles.
Let us know what you decide :wink:
Post by Jerry Coles »
Careful your lift arms don't foull the seat pan otherwise you get a slight lift when the are fully up!!
tom lad
Post by tom lad »
the current seat gets very close to the lift arms if slid back too far on the bolts
agri say they don't recommend it but it should fit , number 6002 .
think im gonna try it.
Brian Cox
Post by Brian Cox »
Hi guys, tell me will the agriline 6002 suspension seat fit on a Dexta ? I was thinking about ordering one :buddies:
tom lad
Post by tom lad »
I hope it does fit
I ordered one today
only issue I could see was the seat base on my tipper pipe ?
will update
Brian Cox
Post by Brian Cox »
Hi Tom lad, my tipper pipe is coming from the front and round the side, so hopefully it should be ok. Looking forward to see how yours fits :clap:
tom lad
Post by tom lad »
parts all came quickly .
quality looks good.
be prepping my MF 65 for ploughing this time ( used the dexta last few years ) not had chance to try fitting the seat yet .
will update .
Post by Bensdexta »
tom lad wrote:be prepping my MF 65 for ploughing this time ( used the dexta last few years ) ...
Why the change?
Brian Cox
Post by Brian Cox »
sorry guys, got fed up waiting. Ordered same seat from Capital Seating, model no. CS01 it's the black one. Price £45.50 plus vat, no charge for delivery.
Went to fit it today, just as well my tipper pipe is flexy, otherwise I might not have made it. Had to remove the plate which holds the tipper pipe in place
as well. Other problem is the height, I honestly think it's far too high , have I boobed ? have not driven it yet that will tell the tale :cry:
tom lad
Post by tom lad »
sorry sirs been busy
not fitted seat yet
wanted to try the 65 this time , the tyre were bad perished , nearer scrap , so I don't use it that much ,and the tin work looks rough.
took the plunge and fitted a full new set of tyres .
good move , I basically prefer driving it to the s dexta , dare I swear like that on this forum :oops: .
I like both tractors neither is going anywhere .
I'm 6 ' 7 " with size 14 riggers , getting on off the dexta if tight / far more room on the bigger tractor .
not a far comparison cuz they aint the same are they
both will be used around the fishery .
and I guess as I cant fix the bobbing hydraulics on the dexta that don't help .my match plough is heavy .
tom lad
Post by tom lad »
finally fitted the new seat
it needed a 6 mm plate under it to clear the tipper pipe
some have commented it looks odd...
I like it , the seat is further back so better for me , makes tractor much nicer , and the springing is good also .
I'm happy with it .
Post by Bensdexta »
Thanks for reporting back.
I've still got my original (repro) seat. Seems OK. Would be interesting to try a sprung seat for comparison as some of our fields are pretty bumpy. :shock:
tom lad
Post by tom lad »
i fitted it and then finish ploughing a small field that I try to do each year , with my 3 fr fergie so 33 " a pass .
I think its nicer to drive now .
got here good and warm to as its not been used that much lately .
that's the first time I've had a email notification re. a post :clap:
