				Removing pto lever
				Posted: Sun Sep 14, 2014 3:23 pm
				by Nick
				Hi all.  I have finally managed to get all other projects done to allow me to get to restoring my 1959 dexta  (photos will follow)
I need to replace both the pto lever seal and clutch pedal bush, to do this though I need to remove the pto lever.  There is what looks like a stub of threaded bar with a nut on it which needs to come out, I have undone the nut but cant get the rod out, is there something im missing or will it need to be heated?
				Re: Removing pto lever
				Posted: Sun Sep 14, 2014 5:06 pm
				by tom lad
				hi
do you mean the pinch bolt thingy that holds the lever on ?
I loosened the nut then tapped it out using the nut to protect the thread , if u understand me ?  it is machined to not twist as u tighten the nut     if u understand me
like a master spline
will make sense once its off.
				Posted: Sun Sep 14, 2014 5:35 pm
				by Nick
				Yes thats the bit!  I did wonder if it was tapped in, but didnt want to break anything!
Yep I see what you mean about protecting the thread, will give that a go.
Thanks mate!
				Posted: Sun Sep 14, 2014 9:04 pm
				by koenr
				I did mine a few months ago. Don't forget to drain your rear axle when you get the 3 bolts of that hold the axle for the pto leaver
				Posted: Mon Sep 15, 2014 2:15 pm
				by Ferdext
				koenr wrote:I did mine a few months ago. Don't forget to drain your rear axle when you get the 3 bolts of that hold the axle for the pto leaver
 If I understand correctly, I have no choice but to empty the differential oïl, and to open the little door "3 bolts" where is the axe of the clutch pedal and PTO, and then the assembly can be taken off ?  ....and at once in hand, it will be easy to change the seal  (where to find it), and the bushing (I alreadey have it).
Please tell me if it it the lone way, because I think it is impossible to change anything without taking out all the assembly !
Thank you for advise.
Gilles.
