Well I took the advise of some here and went to a much heaver alternator wire. I now have the left rear axle pulled to install a new oil seal. Already did the right side. With the oil leaking on the brake pads I had no brakes. With the right one fixed I now had one wheel brakes. When this one is finished I will have brakes on both wheels!!
I am still going to have to have the injector pump rebuilt. It leaks the fuel down and the tractor is hard to start. Have to spin it over for an extended time to get fuel back to cylinders. once it had been cranked it will start right off for the rest of the day. The only hold up on that project is cost!
Repairs
oldcharlie
