snowblowers and lots of snow
strawhouse
I was wondering what size of snowblower to put on my dexta. I was looking at a 72" dual stage single auger blower. The guy said it works fine on any 30 to 40 hp tractor. Any thoughts?
strawhouse
Actually I did pick up a 7 foot single auger dual stage blower. It works extremely well on the dexta, the extra weight of the blower is great traction in the snow and being 7 feet wide it cuts a path wider than the dexta. It will blow light fluffy snow about 40 feet away and it will cut a path into 2 to 3 feet of snow at the end of the road with little resistance. All in all I am extremely pleased with picking up a larger snow blower
strawhouse
As far as the make goes, I was told it was a ford snowblower? It has been painted before but it is in quite good shape. The gear box was clean and the gear drive was in good order. It has a hydraulic chute which is really nice. I just disconnected the hydraulics from the front end loader and use the bucket control for the chute cylinder.
Emil Nyman
