THIS WILL SHOW A COUPLE PICS, BUT MY PHOTOBUCKET SETTING FOR THIS ALBUM IS PUBLIC SO FEEL FREE TO ACCESS THEM ALL IF YOU WANT!!
Bensdexta wrote:I trust you have a copy of the workshop manual?
Sounds like you have a Christmas project!
I checked that.. and it seems to be aligned. Not to mention that in 'neutral' the wheels roll, but as soon as I put it in gear and WITH the clutch in, they lock solid. This leads me to believe there's a bearing failure somewhere. I'll update this post for anyone else that may ever have this problem. Thanks for your responses.oldcharlie wrote:Mine sometimes hangs up and i have to remove the top plate with the shiftier levers re-Aline the slide gears to the neutral position replace top and good to go.
firesweep wrote:I jumped on my Fordson Dexta the other night in the cold weather and cranked it up and after only a few seconds, it seized and killed the engine. It NEVER does this. In fact, it always runs great, uses no oil, starts without either.. anyway, I narrowed it down to a transmission problem. The main shaft seems to be locked. I can start the engine with the clutch pedal in, and it runs. When the clutch pedal is released the engine stops immediately. The rear wheels will ONLY turn when the transmission is in neutral. I'm tearing it down in my shop now, and I couldn't find many pics on this forum to help people with little knowledge of these tractors. So I wanted to post this thread, inviting any and all helpful tips or info, as well as sharing pics of each step of my project for those (including ME) that may need them at a later date.. Thanks in advance for any helpful info.
Thanks Bensdexta.. This piece was laying directly under the clutch housing/gearbox split in the floor in a pool of old oil. The grooves are a perfect match to the teeth on the lower gear, so there's definitely been some major interference there. I have come to the conclusion that it is a piece of the gearshifter... which shows to have been broken and a homemade piece welded on it in place of what was broken. Perhaps this piece was welded on first, or it's the original. Not sure... either way it stands to reason that whatever broke off of the gearshift went into the gearbox and couldn't have easily been retrieved. Gonna begin re-assembly in the morning.. I have found absolutely no other damage anywhere other than the spigot bearing.Bensdexta wrote:Where did you find it? Could it be a foreign object?
Is it complete or does it have fractured surfaces indicating something has broken off?
You've been very quick sorting the spigot bearing!
Yes Bensdexta, the shifter has always had a visible weld on it.. once in a blue moon it hangs up. I'm gonna try to find another one once this is finished. I capped it up today and everything seems to be working smoothly now. I'm gonna go ahead and steam genie it and blast the hood/grille and paint it I guess, while it's all apart. I'm located in the Tri-State area where Tn-Ky-Va all meet. Thanks for your assistance.Bensdexta wrote:I think I'm correct in saying that the original gear shifters are a single piece, ie no welded-on end.
Has your shifter clearly had a new end welded on? If yes then your explanation sounds plausible.
If so, perhaps a previous owner welded on a new end(s) to correct the well-known wear problem on dexta shifters.
Sounds like you've done a thorough job - and fast too! BTW where are you?
Double Clutch.. It was part number A14858, and yes the local New Holland dealer had it in stock. I bought this tractor for bush-hogging on my farm, but have since used it for posthole digging, hay moving, just anything I need.. I've been impressed with how good it's done. It never burns oil, starts without either everytime.. it's never failed me. That's why I had to fix it... too good to put it down.Bensdexta wrote:Just to be clear, does your Dexta have a single or double clutch?
What was the part no of the 'spigot' needle bearing? Did you get the new one from your NH dealer?
BTW What do you use your Dexta for?
