releasing engaged handbrake
Posted: Sun Apr 26, 2015 9:07 am
by botchit
I have a seized handbrake on my 59 Dexta. Is there a way to release the tension before I try to remove the brake drum on the LHS? The handbrake on and will not release. Ideas or comments? thanks Botch.
Re: releasing engaged handbrake
Posted: Mon Apr 27, 2015 8:03 pm
by Brian Cox
I have had the same problem, freed it off at the bottom where the ratchet is using a screwdriver to lever it free :clap:
Posted: Thu May 14, 2015 8:26 pm
by botchit
thanks for the reply Brian but its seems to be far worse than originally thought. Stripping down the brakes to free up the handbrake and fix now :(
